Fixed Correct Matches
Correct score fixed matches app
Day: Tuesday Date: 17.08.2021
League: BOLIVIA Division Profesional
Match: Always Ready – Tomayapo
Tip: Over 2.5 Goals
Odds: 1.50 Result: 3:1 Won
robert7weldon@gmail.com
Fixed matches whatsapp group link
What is Fixed correct matches? In traditional 1X2 football markets fixed matches you are challenged to predict the outcome of a football match fixed betting. Will the home or away side win? Could it even finish as a draw?
Fixed correct matches takes this idea a step further by not only asking you to predict the result but also the exact final score. If it sounds hard that’s because it is but the rewards are also far greater.
Fixed correct matches is one of the easiest betting terms to understand. These bets are extremely popular as they can have long odds which gives bettors the chance to bank big wins.
To win Fixed correct matches you must accurately predict the final score of the match you are betting on. There is no margin for error, it has to be exact. For this reason, it is possible to find good value Fixed correct matches at most bookmakers.
Bookmakers offer Fixed correct matches on a range of sports. However, football matches daily betting tips are the most favoured by punters. Most betting platforms fixed matches provide a list of all the possible correct score options such a 0 – 0, 1 – 0, 0 – 1, 1 – 1, 2 – 1 and so on with the odds for each bet listed, too. Generally, there is also an ‘Any other score’ market as well. This covers freak results where a team scores seven or eight times.
Before considering betting on this market, we suggest you have some background knowledge of the teams that are facing each other. For instance, it’s much more likely that an English Premier League game between Arsenal and Man Utd will produce fewer goals than a game between Arsenal and Swindon Town.
Manipulated Fixed Matches
How to predict Fixed correct matches in football
Predicting Fixed correct matches isn’t easy but, if you get it right, it can be rewarding, particularly when betting with Colossus. So how do you predict correct scores?
The first challenge is to decide who you think will win the match. If you can narrow that down, it reduces the possible outcomes substantially. Websites such as FixedMatch.Bet are useful resources for form tables, home and away tables and plenty more stats to help you form an opinion.
Alternatively, if you’re still stuck, don’t be afraid to check out the odds which will tell you who the bookmakers make favourite. This can be a useful guide but keep in mind that they aren’t always correct.
Once you’ve decided on an outcome, such as the home team winning, how do you narrow down the correct scores fixed matches? A good start is to ask yourself how prolific that team are in front of goal, how resolute they are defensively and ask the same of the opposition.
Example
As an example, let’s create a hypothetical Premier League game between recent champions Liverpool and last-placed Norwich, a match we would assume Liverpool to win.
The Reds scored 85 goals across 38 league games at a rate of 2.2 goals a game. They conceded 33 goals at a rate of 0.86 goals a game. Norwich, on the other hand, scored 0.68 goals a game over the season but conceded 1.97.
We can conclude from this that Liverpool are high scoring. And likely to net two or more goals, particularly against a deference who concedes so many. Liverpool are also strong defensively. Conceding less than once a game on average and might not be trouble too much by an unthreatening attack.
Double Bet Fixed Matches
With this in mind we might want to cover correct scores fixed matches like 2-0, 3-0 and 4-0 to Liverpool or, if feeling very cautious about Norwich getting a goal, 2-1, 3-1 and 4-1 as well. Coincidentally Liverpool vs. Norwich was the very first game of the season and it did finish 4-1 to Liverpool.
This is a very basic and simple approach to correct score betting fixed matches. But you can go into each team’s statistics as extensively as you want by incorporating things like xG, xGa, home and away form, goal margins and so on into your thinking if you wish, all of which are available online.
Fixed odds vs. pools betting
So what is the difference between correct score betting in fixed odds versus pools? At fixed odds bookmakers you have the opportunity to bet on a single game. And you will know your potential return when you place the bet. More common score lines such as 1-0 and 2-0 will tend to have much shorter odds and pay less than the rarer outcomes such as 5-0.
When betting on Fixed correct matches at Colossus, you are predicting the outcome of multiple fixed matches. Typically between three and six in any given pool, with each pool having a jackpot prize that can be won individually or split if there are multiple fixed matches winners. Naturally the more matches in a pool, the greater the jackpot prize, with the Correct Score – Pick Fixed matches 6 the biggest of all.
VIP Fixed Matches Betting Sites
To make football betting fixed games pools betting easier, you can pick multiple fixed matches outcomes per match. For example if you think a match is too close to call but you fancy it to be a low scoring affair. You can select multiple outcomes across home, away and draw to cover your bases, also known as ‘perming’. Be warned though that the more selections you make, the greater your stake will be.
Additionally whereas fixed odds betting is a solo pursuit, pools betting is a social affair. You can create or join Syndicates, a crowd betting solution which allows you to split the cost of your ticket. And any prize money won, with other players to create a fun, social betting experience.
What is the meaning of ‘other’ correct score selections?
Although huge score lines such as 6-1 and 5-0 are rare, they do happen. Just look at Leicester thrashing Southampton 9-0 as an example. When betting at fixed odds bookmakers you would have to select this exact score to win your Fixed correct matches. But Colossus make things easier by grouping unlikely scores into ‘other’ categories.
Any Fixed correct matches where the home or away side win whilst netting four or more times is grouped as ‘other home win’ or ‘other away win’. Similarly, any draw greater than 1-1 is ‘other draw’. We think this is a much fairer way to do things. Read more about the meaning of other home win / away / draw.
